An error occurs stating that the content object has not been uploaded to the server archive.
SH_10729006
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
NARAE NANOTECH CORPORATION (276604) / Hyunsoo Son / 01041225919
Content object "np-05-0302-01214.A.3.dwg" in document "np-05-0302-01214.drw" was not uploaded to the server archive when checked in.
An error occurs. I searched related documents and tried to solve the problem, but the problem was not resolved.
Please check.
Here are the errors that I faced
Translated the text from Korean to English using google translate.
Subject: 컨텐트 객체가 서버 보관소에 업로드 되지 않았습니다라는 에러가 발생됩
Body: I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
NARAE NANOTECH CORPORATION (276604) / 손현수 / 01041225919
체크인하기시 "np-05-0302-01214.drw" 문서에 있는 컨텐트 객체 "np-05-0302-01214.A.3.dwg"이(가) 서버 보관소에 업로드 되지 않았습니다
라는 에러가 발생됩니다. 관련 문서를 찾아보고 해결해보았지만 문제해결이 되지 않고있습니다.
확인 한번 부탁드립니다.
Here are the errors that I faced 체크인하기시 "np-05-0302-01214.drw" 문서에 있는 컨텐트 객체 "np-05-0302-01214.A.3.dwg"이(가) 서버 보관소에 업로드 되지 않았습니다
- By community moderation team
HelesicPetr
(To:SH_10729006)
Hi @SH_10729006
If the upload failed there usually is identification issue.
Check following articles
Number uniqueness
CS198426 - Cannot upload or check in a CAD document
Filename uniqueness
CS24096 - Upload or Check In fails with conflict
PetrH
