Ant script to load and compile .java files
smorla
I have a File uploading utility that loads WTDocuments to Windchill.
I want to load this package onto Windchill and compile it using ant script.
So far, I have managed to copy the package (which is a bunch of .java files) onto the src folder using the following ant script:
<target name="taskUnzip">
          <unzip src="${packagestructure}/myuploadutility.zip" dest="${wc_src}"/>
</target>
I use the following task to compile it:
<target name="compile">
  <javac srcdir="${wc_src}" destdir="${wc_codebase}"/>
  </target>
But this throws several errors similar to :
\myuploadutility.java:5: error: cannot find symbol
    [javac] import com.ptc.netmarkets.model.NmOid;
    [javac]                                ^
    [javac]   symbol:   class NmOid
    [javac]   location: package com.ptc.netmarkets.model
So I think I am writing the tasks the wrong way. So, how to load the package, compile it, so that the .class files get stored in codebase?
Please help.
Thanks in advance.
Note: I know it's possible to make a jar file of all the .class files directly and put them into codebase. However, requirement specifies a .zip file containing .java files only.
You have a compilation error in your myuploadutility.java. It is not an issue with the task. You are importing a package that is not in the class path.
Hi Srinivas Morla
I have not that much exposure to Ant script, but if you wish you can give it a try to compile using below command.
This command will compile classes for you and also place them in respective packages under codebase
tools class -Dclass.includes=ext\**
I am assuming ext is your customization directory under <WT_HOME>\src folder.
Shirish
Hi Shirish,
This worked! I ran the ant script to put the java files in the src folder and used the command line to compile them.
Thanks for your help.
