Anyone using Cognos 4 against Windchill?
MichaelMarshall
WBR is built on Cognos 8.2.
We do have some personnel who are running Cognos 8.4 against our other business systems.
Can you use Cognos 8.4 with Windchill? Any special requirements or incompatibilities? Anyone using 8.4 with their Windchill installation in place of WBR?
Thanks!
Apologies for the bad subject line...I meant Cognos 8.4, not Cognos 4.
Hi Michael, Windchill supports up to 8.2. I'm not aware of any customers using newer versions.
Here is the doc from PTCs site:
http://www.ptc.com/WCMS/files/77024/en/Windchill91M040SoftwareMatrices012910.pdf
Hope this helps.
Blaine Prout
Does anyone know the when/if WBR will be updated to Cognos 8.4?
If you upgrade to Windchill 9.1 M060 allows you to choose if you want to upgrade to Cognos 8.4 or stay with 8.2. If you install Winchill 9.1 M060 from scratch you automatically get Cognos 8.4.
Brian
