Application management in WGM
Luar
Hi All,
I just installed WGM 11.0. I want to upload and publish my solidworks and autocad files but when I try to register
new Application under Tool---> Application Manager--> Application ---> Register New Application it response me nothing that's why I cant register my autocad and solidworks application.
Is there something wrong about my installation?
Luar
LoriSood
23-Emerald I
(To:Luar)
Luar,
When you installed WWGM on the server did you select to install AutoCAD and SolidWorks on the Workgroup Manager install screen in the PSI?
Luar
(To:LoriSood)
Hi Lori,
Yes, I did check the option for that.
Thank you,
Luar
LoriSood
23-Emerald I
(To:Luar)
Luar,
Are you getting a particular error when you try to register? If so, can you provide a screenshot of the error?
Does it make a difference if you run the WWGM client as an administrator?
What versions of SolidWorks and AutoCAD are you trying to register?
Luar
(To:LoriSood)
Hi Lori,
I recorded a video clip on what happens. As you can see I'm connected on my windchill server and when I register new application, nothings happen. No option for my CAD Application.
Video Link : 6937
Thank you,
Luar
LoriSood
23-Emerald I
(To:Luar)
Luar,
What version of the CAD applications are you running? Is it possible you are running into something along the same lines as the issue documented here?
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS170173
