Associate Document to Part (Workflow Expression)
dwilliams
Hello Gurus,
Through a workflow expression, I am trying to associate WTDocument to a WTProduct. Below is the code I am using but it doesn't seem to be correct. The association is not being made. The "equipmentEndItem" is a wt.part.WTProduct variable.
wt.doc.WTDocument doc = (wt.doc.WTDocument)primaryBusinessObject;
wt.part.WTPartDescribeLink describeLink = wt.part.WTPartDescribeLink.newWTPartDescribeLink(equipmentEndItem,doc);
What am I missing?
Thanks for your expertise,
Dax Williams
Business Administrator, Windchill
Lifetime Products, Inc.
-<">mailto:->
[cid:image001.jpg@01CA8234.BD30C240]
saving the link?
wt.fc.PersistenceHelper.manager.save(wt.part.WTPartDescribeLink.newWTPartDescribeLink(equipmentEndItem,doc));
might do the trick 😉
cheers & happy xmas,
martin
Martin,
Thank you. I figured it had something to do with saving the link, I just was sure how to do it. I appreciate your expertise.
Any ideas why I would be receiving the following runtime error? The WTDocument and the WTProduct are both checked into the libraries and neither are in a workspace.
in this case use a server side method to bypass the listeners:
wt.fc.PersistenceServerHelper.manager.insert(wt.part.WTPartDescribeLink.newWTPartDescribeLink(equipmentEndItem,doc));
martin
Martin,
Thanks again. This method works flawlessly.
