Hi All,
I could sucessfully configure AutoCAD worker and it publishes fine the AutoCAD drawings to pdf usingAutoCAD's Acroconsole. Currently Iam using the Plot command. Its convering the drawings layout tab to pdf. Attached is the SCR file iam using in the setup.
Is there a mechanism to publish files with multi layout? or is it possible to publish both the model and layout to pdf ?
Iam not much familliar with autoCAD and hence would like your inputs here. Is it not required to have both Models and layout in PDF ?
-Vaibhav
Hi Vaibhav,
Greetings for the Day!!
I'm trying to configure worker for 12.0.2.3 version of Windchill. Any references or documents would be appriciated.
Durga
