Autocad Workgroup manager
Perttu
Hi, Has anyone successfully installed the Autocad 2009 /2010 workgroup manager for ProductPoint? My installation runs OK, but the VFS is not working. PTC Places icon in control panel or in Tools-menu do nothing. No error messages in installation log files and I have installed all the prerequisites mentioned in admin guide. Have tried it with XP SP2 and Vista SP1. Both unsuccessful. Does this application require some component in OS whicj I am missing. Regards, Perttu
Hi Due to some programming error you need to install the ACAD option with your regional settings set to english. Then everyting will work. After installation you can reset your settings to original. The PTC Places window will look a bit strange but it still works. /Lars Björs
