Automated Revision Change
mwimberly
6-Contributor
Is there a way to automate the changing of the revision of a file when
it is promoted? The way we have things set up is that a file gets
demoted to a lower release level to have changes made. The changes will
cause a revision change. It will then have to be approved to be
promoted back to the released level. Is there a way that when the RTP
is created or initiated that it bumps the revision as well?
TIA
Michael Wimberly
Engineering Applications Support Specialist II
Security & Survivability Systems
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 881-5087 Fax
(513) 881-9800 Main
0 REPLIES 0
