My company is making the transition from using Pro/INTRLAINK 3.4 to PDMLink 9.1. We are a drawing centric enterprise. We used baselines as a part of the drawing issue process in Intralink to capture the configuration of the plotted drawing. In Intralink we used UI scripting to run our issue process, this is how we created the baselines.
I am working on how we are going to issue drawings under PDMLink. I am looking to use a Workflow, I am not convinced that using the OOTB promote process is the way to go. As a part of the workflow I want to setup a step where a managed baseline is created by the process based on the drawing being the primary business object. My skills are in development and so I am asking the community if someone has done this or has a good idea as to how to do this. I am looking to implement some code for a method robot that does this.
-Kelly Lozier
