Hello All,
I recently Bulk uploaded few WTDocuments (PDF's) into out Windchill Server. I did not add the Attribute Values at the time of uploading the WTDocuments. I just wanted to know if there is any way to upload/update the Attribute Values of the existing WTDocuments.
Any suggestions would be helpful.
Kiran Lakshminarayanan
Lakshmi,
Attached is sample xml to update attribute without updating contain.
Hope this helps!!!
Kiran,
its possible to add the attribute values to existing documents,
Please try the same bulk loader with attribute values, documents will increase one iteration.
Hope this will help your problem.
Regards
Ramanathan
