I think we have a problem with parameter mapping in the bulkloader.
Software:
Server 2008 R2, SQL 2008 Workgroup, WSS 3.0, WPP 1.1 M021.
Data:
Part model with real number parameter TEST, value 323.000. Create TEST number column in WPP, add to PTC content.
Process:
Using the bukloader, upload the single part, view the new column, see the field reads 0.323.
Problem:
What if the parameter in ProE is driven by a relation, when you open the bulkloaded part and rebuild.....Ooops.
Why is the bulkloader at fault:
Try loading the same part using the traditional method, no problem with parameter mapping.
Please let me know if you have experienced the same problem.
Alan
