I would like to install the ECAD WGM client without installing InterComm Expert.We don't need to have ECAD visualization now (afforded by InterComm), but want the product structure building and WTPart creation in Windchill (afforded by the ECAD WGM). We are looking to integrate with Zuken.
Has anybody installed the ECAD WGM client in a WC 9.1 environment without InterComm Expert being installed?
Kirk
Hi Kirk,
in January I wanted to do the same and I simply gave a fake (C:\ptc\intercommFakeDir) when the ECAD WGM install wizzard asked for the installation path of intercomm expert. There may be same warnings on ECAD WGM startup but it should work anyway.
Once the installer is through, you can switch off the viewable generation (which is the main purpose of the Intercomm Expert integration to the ECAD WGM) on check-in under File->Preferences->User->Design Preferences->Upload Board/Schematic Viewable
Good luck and kind regards
Paul
