Business Rule
SC_9926422
7-Bedrock
Business Rule
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.3
Business Rule- Attribute validation Configurationt
Example :
Set of Attribute -Subtype of Part1
Set of Attribute- Subtype of Part2
How to Load the Business Rule For these Case
You need to create different rules for each subtype
Rule1 for objectType = wt.part.WTPart with excludedType=<domain>.subtype1 and 2
Rule2 for objectType = <domain>.subtype1
Rule3 for objectType = <domain>.subtype2
Load those rules in to one or multiple rule sets.
Using Attribute Rule ,We Can Configure for Particular Part.
But My Requirement like,
Need to configure  Multiple Subtype with different Attribute.
VK_1647
(To:BjoernRueegg)
Can we use Attribure rule for below condition.
I have one attribute abc on  part subtype
And another  xyz  on change notice .
If xyz has value which strts from like B00.. then part iba abc shoul not be nuĺĺ
Or 2 attributes on same subtype of part can we add conditions inattribute rule.
I don't believe you can do cascading attribute checks out of the box. That's something you need to develop by yourself.
