We are having issues this morning with some of the drawings NOT getting published on the cad worker. We are seeing the below error message when we look at the publish job summary. Note this is only happening to some users/drawings.
I did see the article (CS33760) on ptc.com and still confused on why some users are having problems and others are not.
We are using WC 9.0 M060 and Wildfire4
Thanks for the help.
Mar 4, 2013 11:25:46 AM:Start PublishJob: CAD Part - 74000114-06.prt, A.1
Mar 4, 2013 11:25:46 AM:The EPMDocument Default Config Spec was selected as the default
Mar 4, 2013 11:25:46 AM:make temp dir f:\ptc\Windchill\temp\pubtemp\publish54597.tmp
Mar 4, 2013 11:25:46 AM:Start: CAD Part - 74000114-06.prt, A.1
Mar 4, 2013 11:25:46 AM:Authoring Application: Pro/ENGINEER
Mar 4, 2013 11:25:46 AM:empty temp dir: f:\ptc\Windchill\temp\pubtemp\publish54597.tmp
Mar 4, 2013 11:25:46 AM:Transferring Files to: f:\ptc\Windchill\temp\pubtemp\publish54597.tmp
Mar 4, 2013 11:25:46 AM:Number of Files (identified to be) Transferred: 1
Mar 4, 2013 11:25:46 AM:ProE Part Conversion
Mar 4, 2013 11:25:46 AM:Added request to PROE queue
Mar 4, 2013 11:25:47 AM:Unable to submit job to worker
Mar 4, 2013 11:25:47 AM:Problem creating directory \\ama-graphlib\S_Worker\w1i1j15. Do not have write access
Mar 4, 2013 11:25:47 AM:Part Processing Returned: $ERROR$ Problem creating directory \\ama-graphlib\S_Worker\w1i1j15. Do not have write access
Mar 4, 2013 11:25:48 AM:CadAgent Returned: $ERROR$ Problem creating directory \\ama-graphlib\S_Worker\w1i1j15. Do not have write access
Mar 4, 2013 11:25:48 AM:End (with Error): CAD Part - 74000114-06.prt, A.1
Mar 4, 2013 11:25:48 AM:remove temp dir: f:\ptc\Windchill\temp\pubtemp\publish54597.tmp
Mar 4, 2013 11:25:48 AM:Publish Complete event dispatched
Mar 4, 2013 11:25:48 AM:End PublishJob (with Error): CAD Part - 74000114-06.prt, A.1
Ben,
Windows permissions are always fun. It it isnot absolutely necessary to run both Windchill and the Daemon services as the same user. However, it greatly simplifies the permissions configuration when you do.
Ramanathan is explaining a recommended system administration practice. It is not a good practice to run Windchill relates services as the local system account for a few reasons.
I understand you are in a secure environment and setting up a Windchill service account may not be permissible or possible according to your security policies. (I'm not sure if your secure network has the ability to set up domain accounts.)
Hope this helps.
Kind Regards,
Matt
In Reply to Ben Loosli:
With Windows 2003 and WinXP CAD worker, we have never run them in the same name. The Windchill server services use the Local SYSTEM account for all Windchill, Apache, Tomcat and WindchillDS logons. The CAD Worker uses a dedicated SYSPDMAPP account. This has worked for years. When I try to switch the Windchill server to use the SYSPDMAPP account, the processes fail to start.
Now with Win7 CAD Worker, I can no longer create the directory.
Something is missing!
Thank you,
Ben H. Loosli
USEC, INC.
Marked. This works for me.
