CIP SOAP Client (line 1, column 1): The main XML document cannot be empty
ybhide
PDMLink 8.0 M030
WF3 M200
IE 7
Some of our users are receiving following message at the bottom of Pro/E
screen when trying to save cad files.
empty
This accompanied by pop up that warns of server being unavailable, and
user has chooks yes or no to go offline.
If user chooses yes, he/she's taken offline. But if user chooses no,
everything falls back to normal for some time. User can access
workspace, commonspace, save and check-in files etc. Any clue as to why
system is thinking that server is unavailable pretty much randomly). We
have 1GB network.
TIA
Yugendra
Yugendra Bhide
Design Engineer
Norse Dairy Systems
Columbus, Oh
Ph (614)-421 5305
Fax (614)-421 5438
Hello Yugendra,
Not sure if you have tried this, but can you cross check this?
https://www.ptc.com/appserver/cs/view/solution.jsp?n=138710
In Reply to Yugendra Bhide:
PDMLink 8.0 M030
WF3 M200
IE 7
empty
have 1GB network.
TIA
Yugendra
Yugendra Bhide
Design Engineer
Norse Dairy Systems
Columbus, Oh
Ph (614)-421 5305
Fax (614)-421 5438
http://www.norse.com/
This email and any files transmitted with it are confidential and intended solely for the person(s) or entity to whom they are addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this email in error, please contact the sender and delete the material from any computer.
cforeman
7-Bedrock
(To:ybhide)
Another very common cause of this issue (especially when working in a WAN environment) is the KeepAliveTimeout value in Apache's httpd.conf. In 8.0, the default was 15 seconds, and this was changed to an even tighter 5 seconds in the version of Apache used with 9.0. At our site, we found that a value of 45 seconds seems to work well. The TAN number is 141707.
If you find that the issue is occurring more with WAN users than local users, this is likely the culprit.
-Charlie
