Call custom class
Stanley
Call custom class
Hi all,
I wrote a workflow expression but it was quite long.
So I used javac to create package and store it in proper dir inside codebase/ext.
But when I'm calling my class via expression in workflow manager I get error class not found.
Checking Syntax...
e:\Windchill_9.0\Windchill\temp\WfExpression269020934.java:40: package com does not exist
ext.workflow.myClass(primaryBusinessObject);
1 error
Syntax check complete.
Can you help me, please?
What are you expecting to get by this code?
To get class instance you shoud write "new ext.test.TestingClass();",
To call method "ext.test.TestingClass.main();".
MikeLockwood
22-Sapphire I
(To:Stanley)
Here's an example of a call to a custom class that we use.
Code In workflow Template Activity, on Start Transition
//Add pBONumber to Assignment names
ext.alcon.workflow.WorkflowHelper.replaceInAssignmentName(self, "\\{pBONumber}", pBONumber);
custom class location
D:\PTC\Windchill_10.1\Windchill\codebase\ext\alcon\workflow\WorkflowHelper.class
Called Method in custom class
* Replace a given string with another given string in the names of the assignments associated with the given pBO.
public static void replaceInAssignmentName(WTObject primaryBusinessObject, String replaceThis, String withThat) {
try {
Enumeration processes = WfEngineHelper.service.getAssociatedProcesses(primaryBusinessObject,null,((WTContained)primaryBusinessObject).getContainerReference());
while(processes.hasMoreElements()) {
WfProcess process = (WfProcess) processes.nextElement();
QueryResult nodes = process.getContainerNodes();
while(nodes.hasMoreElements()){
WTObject wtObj = (WTObject) nodes.nextElement();
LocalizableMessage wtObjDispTypeLM = wtObj.getDisplayType();
String wtObjDispType = wtObjDispTypeLM.getLocalizedMessage(wt.session.SessionHelper.manager.getLocale());
String wtObjName = null;
if(wtObjDispType.contains("Wf Assigned Activity")){
wtObjName = ((WfActivity)wtObj).getName();
String wtObjNewName = wtObjName.replaceFirst(replaceThis, withThat);
((WfActivity)wtObj).setName(wtObjNewName);
PersistenceHelper.manager.save((Persistable) wtObj);
PersistenceHelper.manager.save((Persistable) process);
catch(WTException e) {
e.printStackTrace();
LOGGER.error("Error while adding PBONumber to Assignment Name: " + e);
Thanks for your reply.
Did you use standard Javac or Rational Rose?
I wrote simple TestingClass.java
package ext.test;
import java.io.File;
import java.io.FileWriter;
public class TestingClass {
public static void main (String[] args) {
try {
FileWriter outputStream = new FileWriter("C:\\test\\helloworld.txt");
for (int i = 0; i < 25; i++) {
outputStream.write("Hello World!" + "\r\n");
outputStream.close();
} catch (Exception e) {
Placed it inside of <wc.home>\codebase\ext\test
compiled using javac ext\test\TestingClass.java
<wc.home>\codebase\ext\test\TestingClass.class was created
Then I used my class in Workflow Expression
try {
syntax check returned
Checking Syntax...
e:\Windchill_9.0\Windchill\temp\WfExpression269079314.java:39: package ext does not exist
1 error
I catched similar exception at runtime
Thanks a lot, it's functional now.
Beginners mistake.
It was only testing class, and not functional I think.
Now I can move all my expressions into own class(es), yippee.
