Calling LoadFromFile utility in Custom java class ??
vuchekar
Hello All, Normally for Legacy data loading we use LoadFromFile Utility from Windchill shell.
I made .csv file. now i want to pass this csv file to this LoadFromFile utility in a seprate java programe without using Windchill shell.
first i need to call wt.load.util.CSV2XML and then wt.load.LoadFromFile.
How i can achieve this by java program.
Vivek
You can use the LoadFromFile.doFileLoad methods or doLoadFileSet method.
e.g.
LoadFromFile.doFileLoad(filepath, null, null, null, new Hashtable());
where "filepath" is the full path to the file generated by CSV2XML or otherwise created.
Hello Patrick,
Thanks for your guidence,
I use "LoadFromFile.doFileLoad(filepath, null, null, null, new Hashtable());" this method in my program.
it works good.
i need some more little help on same.
this method creates Documents and parts in Site/default folder.
i want to create docs annd parts in Product/Test Product/Default folder location.
how i can do this..
and in above method what is required value at the place of "null, null, null,";
Vivek
You can't make that change with this call. You need to update the XML you are loading. Since you are using CSV2XML, there is probably a way to put the info into the CSV before you generate the XML. Take a look at the CSV and try updating there.
