Can´t install Client manager on Windows 7 64bit
HaraldHengstenb
Hello, i just set up a machine with Windows 7 Pro 64bit. Setup of ProE Wildfire 4 M120 worked fine and it runs great. But when i try to install the Client Manager for ProductPoint it fails because it can´t find .net 3.5 SP1 Framework. .net up to v3.5 SP1 comes with Windows 7. I activated it in the System-Configuration too. Anybody an idea?
I have Win7 64bit too and client installs just fine without any additional installs. Maybe download .net 3.5 Sp1 from MS and try to install it over built-in version. It is probably registry related problem and this could fix it. BTW, which PP version do you use?
We have PP 1.1 F000. Unfortunately I can´t download M010: it´s not listed in my downloads. Why? I tried to install the client on an other machine with Windows 7 32bit with the same result.
please open a call or send and email to - to update your license. hope this helps
Problem solved! Windchill ProductPoint 1.1 M010 has Windows 7 support.
Where is possible download the addon Windchill ProductPoint for work in Windows 7 PRO SP1 64bit with ProEngineer WildFire 5.0?
Can you show the direct link for download it, please?
