Can any one tell me how I can delete Latest Iteration of WTDocument
ptc-3953915
I am stuck in one place I guess any one of you can help me, basically I am trying to delete the latest Iteration of the WTDocument using
PersistenceHelper.manager.delete(persistable);
where persistable object is latest iteration of WTDocument but when I execute the method it delete the entire version of the object
Can any one help me how I can delete only latest iteration of object
rmk
7-Bedrock
7-Bedrock
(To:ptc-3953915)
Hi Ankit,
You can use the following Code to delete the latest iteration,
wt.vc.wip.Workable iterationObj = null;
boolean isLatestIteration = false;
wt.fc.QueryResult result = wt.vc.VersionControlHelper.service.allIterationsFrom((wt.vc.Iterated)WTObject);
while (result.hasMoreElements() ){
WTObject tmpObj = (WTObject)result.nextElement();
if(WTObject instanceof WTPart){
WTPart part = (WTPart)tmpObj;
isLatestIteration = part.isLatestIteration();
if(isLatestIteration){
iterationObj(part);
break;
if( isLatestIteration ){
wt.vc.VersionControlHelper.service.deleteIterations((wt.vc.Iterated)iterationObj,(wt.vc.Iterated)iterationObj);
strLogger.append(" :: Object Deleted :: Yes" );
BR
MKR
Take a look at VersionControlHelper.service.deleteIterations. Not sure if theres a deleteLatest, so getting the iteration you want to delete may be up to you.
Message was edited by: Matthew Knight. Fixed typo
rmk
7-Bedrock
7-Bedrock
(To:ptc-3953915)
Hi Ankit,
iterationObj(part);
break;
BR
MKR
