I have followed an article to enable the S3 for windchill vaults but not able to configure from windchill UI in vault configuration utility.
Configuring Windchill File Vaults to Use Amazon S3
@avillanueva thanks for your reply.
yes, the steps were clear, but I was confused on what path should be given when mounting from Vault configuration utility.
although I could be able to follow hardcoded path shown in my S3 bucket.
I have not done this before but documentation appears clear. Perhaps you can detail your steps and show what errors you are seeing.
