I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS17
When upgrading to SW 2021 from 2019, there was no 2021 option. I reinstalled the WGM and add the 2021 option. Removed the 2019 option and tried to add the 2021 option but there was no option. Removed and installed the WGM with only the 2021 option. But only the 2019 option is available. How to we get the WGM link to the 2021 application?
You will probably need to upgrade your WGM to a newer version that will support SolidWorks 2021.
It appears that the CPS you already have installed supports Solidworks 2021.
If you have problems you could install the CPS that supports the next version of SW which is CPS23
Hi @dkock,
Anurag
