Can't get the value of my attributes
VINO
I'm trying to get the values of my custom attributes of a part.But it gives the result as zero.
I have used the following code.Someone help me out
public static void getIBA_WTP_Attr(WTPart wtp){
try{
System.out.println("Inside avi test");
//Locale locale = Locale.getDefault();
wt.iba.value.IBAHolder ibaHolder=wt.iba.value.service.IBAValueHelper.service.refreshAttributeContainer((wt.iba.value.IBAHolder)wtp, null, null, null);
//wt.iba.definition.service.StandardIBADefinitionService defService=new wt.iba.definition.service.StandardIBADefinitionService();
wt.iba.value.DefaultAttributeContainer attributeContainer=(wt.iba.value.DefaultAttributeContainer)ibaHolder.getAttributeContainer();
AbstractValueView[] abc= attributeContainer.getAttributeValues();
AttributeDefDefaultView[] xyz= attributeContainer.getAttributeDefinitions();
System.out.println("length is "+abc.length);
for(int i=0;i<abc.length;i++)
System.out.println("1-"+abc[i].getLocalizedDisplayString());
System.out.println("2-"+xyz[i].getLocalizedDisplayString());
Thank you
0 REPLIES 0
