Can we make use of "CreateChangeRequestFormProcessor" which I assume to be OOTB to trigger workflow
  • February 3, 2023
  • 2 replies
  • 841 views
Can we make use of "CreateChangeRequestFormProcessor" which I assume to be OOTB to trigger a workflow?
I have an action that has no .jsp but this FormProcessor in the custom-actions. When the action is clicked, the change request UI shows up as wells a workflow is initiated. I'm just curious how.
Hello @MV_10441462
From my knowledge, there is no OOTB feature able to do that.  Maybe the opening of the change request UI triggers an Event like PRE_STORE and then a custom listener in your system initiates this workflow. (https://www.ptc.com/en/support/article/CS214710)
BR,
Pascal
avillanueva
23-Emerald I
23-Emerald I
February 4, 2023
So this processor I believe takes the input from the Change Request wizard and processes it to create a CR. When the CR is created, a lifecycle is assigned which has tied to its initial state, a workflow.
