Can we setup both PROE and Solidworks in Windchill ?
KV_12355386
6-Contributor
Version: Windchill 12.1
Use Case: if PRT file is published then it should go to PROE and if SLDPRT is published then it should go to Solidworks. publish.publishqueue.setnames=PRINT CLASH THUMBNAIL PROE SOLIDWORKSM SOLIDWORKSL publish.publishqueue.sets.0.0= publish.publishqueue.sets.1.1=PROE SOLIDWORKSM publish.publishqueue.sets.1.2=PROE SOLIDWORKSL publish.publishqueue.sets.1.3=PROE SOLIDWORKSL publish.publishqueue.usesetworkers.filtermethod= publish.publishqueue.usesetworkers.forqueueset.PROE=PROE publish.publishqueue.usesetworkers.forqueueset.SOLIDWORKSL=SOLIDWORKS publish.publishqueue.usesetworkers.forqueueset.SOLIDWORKSM=SOLIDWORKS
Description:
I had setup both PROE and Solidworks, but the configuration works only for Solidworks or only PROE but not both. if a PRT is published then it should go to PROE and if SLDPRT is published then it should go to Solidworks.
Dobi
(To:KV_12355386)
Did you already make updates to the java code here:
  • Refer to <Windchill>\prog_examples\wvs\com\ptc\wvs\server\publishPublishQueuePrioritiesFilterExample.java
  • This sample performs no actual setting of Publisher Queue Set or Publish Job priority and will require customizing for your own business purposes
Dobi
(To:KV_12355386)
Looks like you're trying to set up individual queues that separate out the parts by Authoring Application, yes?
A bit old (perhaps outdated) but this used to have required a custom filter (see this post).
CS132318 might be what you're looking for.
KV_12355386
6-Contributor
(To:Dobi)
Yes, your right.
I did setup separate queue for both PROE and Solidworks.
Dobi
(To:KV_12355386)
KV_12355386
6-Contributor
(To:Dobi)
Looking into the code..
Hi @KV_12355386
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
