Hello Steve Haberman,
I'm Charles from PTC Tech Support in Europe, regarding this question can you provide the full error message you're seeing in the Windchill UI / MethodServer? Any further details regarding the use-case?
I will be grateful if you can send me this information.
KR,
Charles.
Here is some output from method server log.. it is not from the same query as above but you can see that the 'ptcUniqueOrganizationIdentifier' value that is input in the GUI does not make it into the sql query where clause.
2022-02-17 13:10:05,985 DEBUG [ajp-nio-127.0.0.1-8010-exec-3] wt.org.QueryPrincipalsServerHelper wcadmin - In getDatabasePrincipal : principalClass class wt.org.WTOrganization, criteria(((name='*steve*'))&((ptcUniqueOrganizationIdentifier='*123*'))), containers.size() : null
2022-02-17 13:10:06,001 DEBUG [ajp-nio-127.0.0.1-8010-exec-3] wt.org.QueryPrincipalsServerHelper wcadmin - filter value: (&(name=*steve*)(ptcUniqueOrganizationIdentifier=*123*))
2022-02-17 13:10:06,001 DEBUG [ajp-nio-127.0.0.1-8010-exec-3] wt.org.QueryPrincipalsServerHelper wcadmin - getDatabasePrincipal qs: SELECT A0.*
FROM wt.org.WTOrganization A0
WHERE (UPPER(A0.name) LIKE '%STEVE%') AND (A0.internal = 1) AND (A0.status = 'public') AND (A0.disabled = 0)
joins=null
I don't use CAGE codes, but it sounds like it's hitting the 50 user limit in the participant search. Maybe try increasing this setting in Windchill. Make sure to restart the Windchill processes after making this change.
xconfmanager -s com.ptc.netmarkets.userSearch.maxCount=500 -t codebase\wt.properties -p
Thank You for your reply!
I should have explained the issue better.. The problem is not that it won't let me see the results. The issue is that adding more detailed criteria does not reduce the size of the result set. There is something causing the cage code criteria to not be included in the database query.
? SPR 13575247 ?
I also see in 12.0.2.2 that when searching for an Organization, the Organization ID criteria (CAGE code) is ignored. Whereas it is taken into account when searching for users.
Unfortunately above SPR is not fixed, neither 12.0 nor 12.1.
KR,
Charles.
I have opened ptc case: C16266449
Thank you for your research!
