We are working on using the OOTB Windchill Change Managment Functionality. So far our process fits fairly well into the process. I have questions about creating the Implementation plan, specifically for tasks that do not change CAD models.
The tasks generated in the Change Notice by default appear to be intended as a mechanism to track the process of Revising a released CAD file. I would like to also use these tasks to generate assignments to perform testing, conduct supplier reviews/ changes and other tasks outside of Pro/E (Creo). As usual, I presume I am missing something obvious.
Bob Lohbauer
Thanks to all who replied (To Steve: Sorry about the noise, Butthat's more about themaintenance of the truck than a feature of the product.)
I should have mentionedupfront thatI am currently working with 9.1m062 first. But Steve's reponse just makes the path to 10.1 more attractive.
My initial concern was how to create tasks in the CN that werent CAD.Which was simple, you just bypass the Affected/ resulting page.
There's a lot to this process when trying to dovetail an existing process into a new structure. Luckily our current change process matches that of PDMLink (At least it has so far...)
