Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hi Mike,
I know this is an old post but, how did you add the ECN number to the front of the Workflow Task name? I tried to add {primaryBusinessObject} to the Name field of the Activity node but that didn't work.
Hi Raymond,
My client having similar type requirement and have tried the above code for WTDocument Type, however while executing the Check Syntax, Its giving errors,
Kindly help me out to execute the same.
Do i need to create *.java file to execute the above code?
Thanks in advance.
Mahesh Kumar G
What is the code that you're using to give you syntax errors? Can you post the code?
Ben,
I am using this below code for WTDocument Type "FM01",
I have created workflow variable, "number",
Code:
java.lang.String number = ((wt.WTdocument|com.ptc.abc.FM01)primaryBusinessObject).getNumber();
wt.workflow.engine.WfActivity myActivity =(wt.workflow.engine.WfActivity)self.getObject();
String prefix=myActivity.getName();
if (!prefix.endsWith(number)) {
java.lang.String Activity_Name = prefix + ": " + number;
myActivity.setName (Activity_Name);
myActivity = (wt.workflow.engine.WfActivity) wt.fc.PersistenceHelper.manager.save(myActivity);
Please find the Syntax error,
Checking Syntax...
F:\ptc\Windchill_10.2\Windchill\temp\WfExpression2582982.java:28: error: variable number is already defined in method executemethod_1(Object[])
java.lang.String number = ((wt.doc.WTdocument|com.abc.FM01)primaryBusinessObject).getNumber();
F:\ptc\Windchill_10.2\Windchill\temp\WfExpression2582982.java:28: error: cannot find symbol
symbol: class doc
symbol: class abc
Note: F:\ptc\Windchill_10.2\Windchill\temp\WfExpression2582982.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
3 errors
Syntax check complete.
Hi Mahesh,
Please change to
java.lang.String number = ((wt.WTDocument)primaryBusinessObject).getNumber();
Sudhakar
Hi Sudhakar,
I am using WTDocument sub type, shall i use full name for sub type document or Only WTDocument Name?.
Thanks in Advance.
Mahesh Kumar G
Hi Mahesh,
For all MBAs you use WTDocument If you want get Typed Attributes use LWCNormalizedObject.
Sudhakar
Mahesh,
I also notice some other things just by looking at the code.
number = ((wt.doc.WTDocument)primaryBusinessObject).getNumber();
