Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
You can edit layouts to make them show you whatever you want. If there is a layout group with the "default group" box checked then it will automatically display any new additional attributes in that group when they are added to the type. It looks like you have some custom groups there "Customer Change To Order" that just simply haven't been fully setup yet. If you edit the layout and drag the items over, you'll see them there.
