Change object version from milspec to an IntegerSeries in level.1 and level.2
Alex_L_Arsandis
2-Explorer
Hello to everyone,
My problem depends on windchill 12.1.0.0
After I changed the versioning of the object by object initialization rules, I get this when I try to build an object:
ATTENTION:
For input string: "A"
I changed from milspec to IntegerSeries in level.1 and level.2
There are no objects I created before with milspec So I guess, it's not about previous objects, created by different version schema.
Did anybody had the same problem and solved that?
Thank you
Objects like CAD, WTParts, WTDocuments are both:
- Revision controlled
- Versioned
Change objects are only
- Revision controlled, with the Revision not displayed by default and the Revise action not available by default
If you want to configure such that change object Revisions are used, that is done globally and so affects all such objects.  They will not be versioned, so only one level will apply.
Look for this topic in Windchill Help: Change Modification Tracking
- Versioned
