Im looking for a way to lock (change to status Under review) resulting objects during Design review. We have a similar process for Promotion request with following expression :
wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
try
wt.maturity.MaturityServerHelper.service.lockTargets (pn);
catch( Exception wte )
wte.printStackTrace();
Is there any way to apply this for Change activity resulting objects?
Thank you very much in advance.
Hi @RUK1
Yes you can write own code to change the state, or check the lock transition and based on the lifecycle configuration you can change the state.
You need to write own code to do so.
PetrH
Hi @RUK1
PetrH
as I expected, I will take a look into that, thank you.
