I would like to be able to change the width of the Attributes table in a Change Request/Notice. Currently, when a user goes to the General-->Attributes and Content page, he may not be able to see all of the Description/Proposed Solution fields. They are just cut off, and you have to use the Tool Tip to view the info.
Using Windchill 9.1 M050
Arron Cochran
Same here. Interestingly enough google chrome will let you resize the window. It also provides a handle in the lower right corner of fields which are dispalayed with a scrollbar by the other browsers. for instance the description field of a new PR (see picture).
It seems to work only with input boxes though.
Vincent
In Reply to Mike Lockwood:
It's a terrific pain to try to read the text by hovering your mouse over the 3 dots. Users were extremely frustrated by this.
We have a patch and a configuration that changes the behavior to provide a hyperlink once the number of characters is > 20, resulting in a separate popup window in all these cases. Can get the details from Preeti.
