Version: Windchill 12.1
Someone made a check-in but filled in the wrong attribute field.
Now I need to fix it by leaving it blank, but when I try to check in, it says that I can't do that because the field cannot be removed. Any ideas on why this is happening and how to fix it?
Just to add, the field is a string and have no restrictions, and it's an asm file.
What is the exact text of the error you received?
exactly that, I guess the only solution is using the CAD...
