Check in with no dependents
EricHuffman
2-Explorer
Gurus,
I'm checking in CAD files from the Pro/E embedded browser when I noticed some mission options. Where is the setting to change the dependents from All to None? In PDMLink 9, I was able to check in with no dependents. Also, I was also able to remove items from the list. Where did that go?
Wildfire 4.0 Datecode m220
Windchill PDMLink 10.0 Datecode m030
Eric
Not applicable
(To:EricHuffman)
You are checking in new objects, therefore you do not have the option to
check in with No Dependents.
WC must have at least one iteration of a file in order for you to
exclude it from your check-in.
~Dan
