Checkin option not available in creo illustrate 6.1
dpchavan
9-Granite
  We have configured windchill in Creo illustrator but checkin options are not available in creo illustrate 6.1. How we can checkin creo illustrate file in windchill.
Dhananjay
There is no checkin button or command! I opened up a case since I believed that this is a bug. There is already an article describing, that you need to create a new File to checkin the current one. See CS320314
The response from PTC was:
I discussed the possibility to patch Illustrate 6.1 with R&D but it turned out that it is not feasible as this specific issue became obsolete as we have introduced enhanced workflows and options to manually check-in and check-out files (from a workspace).
This is an enhancement we cannot port it back to a patch of 6.1
Also 7.0 is scheduled to release in June, a patch would not appear a lot sooner anyway.
So you can open up a new case and ask about a patch, or you need to create a new file to checkin....
