Marc,
I am not sure if I understood your question/scenario.But there is OOTB loader available to load the multiple Iteration/Revision of single document. attached is the sample load csv and xml file. (you can change loader while loading document from network drive)
Hope this helps !!
Shreyas
Hello Marc,
I belive this clean-up can be done with Custom-CleanUpTool that has to do the following sequentially with good exception handling capabilities ,
1.check-out the latest version of the document
2. get all the latest iteration of all revision of the document
3. fetch the content path in the vault for all the revisions obtained in step 2
4. Attach all the previous contents (determin Primary / secondary) to the Ver C.2 . Check-in document.
5. Refreh & Purge old versions for the document (optional , but good to do)
regards,
Sriram Rammohan
