Comma Charactes in XML Load File
pwilliams-3
10.1 M040
Hi Everyone,
I am trying to load an attribute value with the LoadFromFile command IBAValue. However some of my data has a "," comma character in it. How can I specify an alternate delimiter on the CSV2XML command line in a Unix shell. The following command line doesn't work.
windchill wt.load.util.CSV2XML -input "WM Mig Forced Finish - Create.csv" -root "/opt/ptc/WC01/Windchill_10.1/Windchill/loadFiles/com/steelcase/container update" -mapfile "/opt/ptc/WC01/Windchill_10.1/Windchill/loadFiles/csvmapfile.txt" -delimiter \"|"
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CFCC25.6538EF00]
-delimiter \”\|\” worked.
[cid:image002.jpg@01CFCC28.12F57CB0]
