Gurus,
I wanted to configure my Windchill instance with the Eclipse.
Does anybody have the documentation/step by step guide which explains the procedure in detail? Please share at -.
Mayur
If you mean that you want to configure Eclipse on your Windchill server instance to develop Windchill customizations then I think http://www.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=WCCG_Oview_GetStartCust_CustSetup&action=show is what you are looking for
Message was edited by: Jørn Hansen (Of -> If ... stupid tablet with non-english autocorrect)
Hi Jern,
I have configured eclipse with windchill using "ant -f bin/tools.xml eclipse_project" cmd and import the cust_windchill_src..
I m able to created and compile java files successfully.but for jsps,xmls its not working..
is there any configuration for jsp's,actions(netmarkets,config folder)
Hello, there is a video of training for example from the documentation
https://www.youtube.com/watch?v=-14BSAwteVw&list=PLjm4gmbLQwoeqQSP7xUhCnInGknqTBAZV&index=2
