Connect Windchill to an external database using JDBC Connection
aachanta
Hi All,
I am Aditya. I would like to know how to connect Windchill to an external database using JDBC Connection. In case if we can connect Windchill to an external db without using JDBC connection, I would request you all to please let me know how that is possible.
So kindly request you to all please let me know how can we connect Windchill to an external db using a JDBC Connection and also if we there is any other way to connect to an external db so that we can retrieve the information from an external db.
Thanks in advance
Best Regards,
Aditya
Hi @aachanta,
To connect to other (non-Windchill) database, PTC provides Info*Engine JDBC Adapter.
You can find additional information about JDBC Adapter at https://support.ptc.com/WCMS/files/137153/en/JDBCAdapterGuide.pdf
I hope this helps you!
Shirish
Hi @aachanta,
Shirish
