How have you helped justify the costs (hardware, implementation) of creating a Development/Test Environment? Other than it just makes sense not to test changes and updates in Production, how would you convince someone in upper management to approve the expense of creating a Development/Test Environment? There are costs associated with shutting down production, but it seems self-defeating or incriminating to use as justification that we could avoid $x in downtime that I may potentially cause in testing…
Thanks for the input Ben. It seems a little silly to need justification for something so obvious, and when the potential damage could be so large. I'm not really sure how to quantify that damage and use it as part of the justification.
I agree this is one of those several obivious scenarios which need to be backed by logical explanation for management.
Sometime managements do understand that these environments are required but need calculatios on excel sheets to be just in place.
There are few markers that you can research on relative to your organization -
