In Reply to Prathap Yalavarthi:
Hi Prathap,
Good suggestion. Actually, there was plenty of RAM. Turns out the WC instance was set up to allow a remote Java debugger to attach. Seems that when this is the case, only one MS and no BMS is allowed. The details can be found in CS96048. The offending property setting was:
Once I commented that out, all was well.
Ben
Hi Ben,
Check the memory heap settings and see if there is enough memory to
bring up 3 servers. Most common issue I have seen when MS doesn't come
without any log is insufficient memory.
wt.method.maxHeap,wt.method.minHeap
Prathap <
