Hi All,
If I want to get the count of all the objects in all object types how would I be getting the same ?
Is there any nested query or program for the same. Please let me know about it
Best Regards,
Aditya
You should take a look on the QueryBuilder / Reports.
Depending on whether you want the count per sub type, you may have to join the table per typedefinition.
Florent
Hi
How would I get the results if I want to get all the document, part objects, folder count, change request and other objects which can be versionable or non versionable in one single query ?
is it possible for us to have one script for that ?
If yes can you please let me know like how can that be done.
Best Regards,
Aditya
Do you have access to the database? Toad can should you table counts very easily.
Run simple queries against the database for each object type.
For CAD:
select count(*) from epmdocumentmaster to get all unique (e.g. 123.prt, 455.prt).
select count(*) from epmdocument to get all versions (e.g. 123.prt A.1, 123.prt A.2, 123.prt B.1 etc.).
For WTDocuments:
select count(*) from wtdocumentmaster to get all unique
select count(*) from wtdocument to get all versions
For WTParts if used:
select count(*) from wtpartmaster to get all unique
select count(*) from wtpart to get all versions
Hi Mike,
Best Regards,
Aditya
For this, I'd suggest to query (in Windchill, not directly to the database) as count(*) against wtObject, and then apply Group By to the Object Type. Runs into a bit more but can be done.
May lead to a small consulting gig.
