Hi All,
Can you please help me in creating a Sub Project? I am unable to find an option to create a sub project in ProjectLink. I have logged in as Project Manager for a Project. I also checked in the help center, which suggested me to click on Sub Project Icon from the Project Plan Page. But I am unable to find the icon.Please suggest
Sitanshu
You will only see this option if you are in 9.1 or in 10.X using classic project template, the new “enhanced” project templates doesn’t have this option OOTB…
Warm Regards
Guilherme Rocha - Tech Consultant
PLM Solutions do Brasil
“A goal without a plan is just a wish.”
I suggest you to evaluate the classic project templates, if them satisfy your requirements you can use them in 10.1, other than that you can evaluate the program functionality, I dont know much about programs but I know they where designed to manage networks of projects which are related if I recall correctly... In this case you will not create a subproject but a new project under that program.
Evaluate it well because programs are very similar to projects but they doesnt have all the project's functionalities.
I suggest first you evaluate the classic templates once they already have what you want, but be aware of the differences of functionality between the classic and the new EPP templates.
Warm Regards
I found this link with the differences between both classic and EPP templates, maybe you will need to create a ptc account:
http://www.ptc.com/cs/help/windchill_hc/wc100_hc/ProjMgmtPlanTypeConvert.html#ProjMgmtPlanTypeConvert_ConvertingPlanTypes527_12
Good luck
Warm Regards
