I am looking for a way to use the representation from a EPM Doc (in this case a PDF) to create a new WT Doc. The worker is making the PDF on the EPM Doc but then that PDF is a starting point for a document that would have different rules and Life cycle from the original EPM Doc. I thought that there was a republish command that would allow the result to be a new object. Does anyone have experience doing this?
I haven't personally done this but I think what you're looking for is the "AdditionalFilesPostPublishDelegate".
Thank you, we will take a look at this.
