Aha!
I had found the SubFolder type, but evidently you need to leave the permissions at full? Removing some of the permissions seems to disable the ability to create a folder at all...
I tried to not grant Change Domain, Change Context, and Change Permissions, but then was unable to create a folder...
-marc
Hello all,
I'm also having the need to allow a role in a context to create subfolders in that context. I have the ACL set in a manner described in this thread:
Domain: PDM
Context: (our company organization)
Type: SubFolder
State: All
Principal: Super User
Grant Permissions: Full Control (All)
Yet when I test this with a normal user in the Super User role, they are unable to create subfolders. The option is not on the File New menu.
Our Windchill: 9.1 M050.
Anyone had this experience and overcome it?
If you are looking for folder level access controls similar to how INTRALINK 3.4 worked then you need to check out a presentation Ross from Fishbowl Solutions gave a couple years ago at PTC User (or was it Planet PTC).
He walks thru the manual steps, which are many...but if you only need to manage a couple then it's not bad. However, we have customers that required to manage thousands so we created a product to do this.
It's on our website at http://www.fishbowlsolutions.com/PTCSolutions/FishbowlPTCAutomationandIntegrationSolutions/SolutionsForPDMLink/linkSecurity/linkSecurity
The web page mentions 9.1, but we have updated for 10.X.
I've also attached the PPT from the other year so you can see the manual approach (granted it was probably 9.1).
Hello all,
Thanks for the fast replies!
After some digging we found that it was indeed a Profile that was hiding the New Folder command.
Thanks again!
