Creo 10/11 compatibility with windchill 13, why 10 or 11 which is more better with pros and cons ?
Hi @KD_13234270
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
I would think the experience with Windchill would be about the same. You should consider the support calendar for Creo 10 and 11 as a better driver for deciding which version to jump to.
https://support.ptc.com/cs/release-calendar/index.html
