Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
2000 E. El Segundo Blvd. El Segundo, CA 90245 USA www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged. Unless you are the addressee (or authorized to receive mail for the addressee), you should not use, copy or disclose to anyone this message or any information contained in this message. If you have received this message in error, please so advise the sender by reply e-mail and delete this message. Thank you for your cooperation.
There is nothing else to download. The 32-bit and 64-bit are on the one DVD. Like you said it auto detects and loads. Do you have a 32-bit machine around to try an install on and see if it works there?
