Creo part created from a step import does not show in CreoView.
After creating a Creo part from a .step import and doing a standard or auto check in to Windchill the part does not show in CreoView. In order to get part to visualize we found we have to do a custom check in with models and viewables selected. In addition all assemblies that the part is used in will not show the component unless the assembly is also checked in using the custom check in and the models and viewables selected. This was not an issue with our previous system WC 9.1 and Wildfire 4.
Using CreoView 3.0 M020
Using Creo 3.0
Any suggestions?
