Current Active Users "too high"
akelly
Using Pro/Intralink 9.1
The Server Status (Site Utilities) shows too many Current Active Users. Is there any way to get a list of who those Current Active Users are?
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
jessh
(To:akelly)
From a Windchill shell,
java wt.util.jmx.SMJconsole
This will launch jconsole connected to the (default) server manager.
You can then click the Monitors tab, then com.ptc -> Monitors ->
ActiveUsers -> Attributes in the tree in the left panel. The
TotalActiveUsers attribute should list the active users.
Jess Holle
> Users are?
akelly
(To:akelly)
My tab is called MBeans instead of Monitors. Otherwise it worked.
Thanks Jess.
Now for the bonus question - why is it double-counting every user? Each
user is listed twice - each one has different capitalization.
jessh
(To:akelly)
> Thanks Jess.
Oops. That was a typo / brain-o on my part
> Each user is listed twice - each one has different capitalization.
Interesting. I'm not sure why. I'm bcc'ing some folk who might as this
should be addressed.
akelly
(To:akelly)
I'm using 9.1 M030, which is using WindchillDS instead of Aphelion.
