Hi.
I customize the item picker. I am using multiselection mode, but after selection picker show only firrst selected object. How can I customize my pixker for showing all selected objects?
Hi Anton,
It may help to have your Winchill Version as well as your picker configuration.
May first guess would be to check to make sure pickerCallBack is being properly defined.
Jarrett
Hi Jarret!
What is default pickerCallBack js function? I need it to understand how it should be created.
Hi Anton,
The pickerCallBack function is defined in custom.js.
Here is an example from the Customizers Guide:http://www.ptc.com/WCMS/files/154113/en/10_1_M040_WindchillCustomizationGuide.pdf#1021
Here is an article that also might be helpful: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS73026
Jarrett
