DB connection between WTChangeRequest2 and WTDocumentMaster?
ptc-2210193
I am trying to come up with a way of showing open change requests to users when they run alittle java app...all I need to do is to run 'selects' against the database. However, I am unable to make the connection back to the name of the document that the change request is written against in WTDocumentMaster. With an out of the box workflow, I am able to track it all the way back and grab the name, however our engineering department has decided that it needs fully custom workflows that, incidentally, do not write to the same tables in the DB as the OOTB solution does. Any ideas on where to look for that link?
Steve Jones
0 REPLIES 0
